PV Sol has suggested I can input three strings into one tracker for a Solis inverter. However the manufacturer's design software only enables 2 strings. Why has PV Sol recommended an option that isn't possible?
I've attached screenshots of both designs. I'm using Trina TSM-420DE09R.08 panels and the site is in Colchester, UK.
Hi RachelEnergy,
recently, another user had the same issue:
We made some minor changes to PV*SOL premium 2023 R4 in order to make it more obvious to the user that there are cable combiners necessary in some occasions.
Thanks Martin, that would be a useful addition to advise cable combiners are needed if there's more than 2 strings per input.
The manufacturer has since confirmed an issue with their software, it should allow 3 strings as it's within the voltage range but there was an glitch and it wasn't allowing it, but an older version was.
  • 1 month later...
