PV CD -315kWp.pvprjHello, In this file, I set operation time to 2023/1/1,which is Sunday. And i set no consumption at weekends. But i checked the hourly values , there was still consumption on that day. The table shows that there was no consumption on January 3rd and 4th.  There should be a problem with the setup. Please help to check.
PV CD -315kWp.csv
Hi Venco Gary,
the date of the start of operation is not considered in the simulation, only in the economic calculation (for the tariffs for example). The reference date for the load profiles is arbitrary and set to 01. January 2015 internally. So the first day of your load profile will always be a Thursday, if you choose to "Define Load Profile" like you showed above.
