Esteban Posted March 31, 2023 Report Posted March 31, 2023 Hey there! I just want to know if it's possible to print reports with different companies. I work for two different companies and every time I switch between them I have to erase all the info (including logo) and enter again the other company info. Is there a way of doing this with a template or something like that? I tried changing the export settings of the report but did'nt find anything there. Thanks in advance! Esteban Quote
developer_mh Posted April 3, 2023 Report Posted April 3, 2023 Hi Esteban, thank you for the feature request. We already have it on our list, but I can't give a date for this yet, I am afraid. What you can do right now is to swap the corresponding lines in the PVSOL.ini. Just have a look at the file here: C:\Users\USERNAME\Documents\Valentin EnergieSoftware\PVSOL premium 2023\PVSOL.ini There is a line that starts with "Benutzerdaten": <Benutzerdaten Ansprechpartner="" Unternehmen="" Adresse1="" Adresse2="" Land="" Telefon="" Telefax="" EMail="" Bildpfad="" /> You can edit your data in PV*SOL, close it an then copy the line to another file. You do that for both your companies, so that you just have to paste the correct line before starting PV*SOL. Hope that helps, kind regards, Martin 1 Quote
