Maha Dardir Posted May 14, 2018 Report Posted May 14, 2018 Dear All, I have a roof with a room built on it and I have filled the roof in the 3D model with panels on both the roof and the room on the roof. However, when trying to configure the whole roof on a single inverter each area must be configured on a separate MPPT . Is there any way to avoid that ? Please see attached screenshots from 3D design : Quote
developer_mh Posted May 14, 2018 Report Posted May 14, 2018 Hello Maha, to achieve this, you can use the 'Configure Module Areas together' feature. See this post here on a similar question: When you search the forum, you will find some more information on that. Hope this helps! Kind regards, Martin Quote
Maha Dardir Posted May 15, 2018 Author Report Posted May 15, 2018 Thank you Martin. This helped a lot. Regards, Maha Quote
