Q1: Mean Temperature use in PVSOL premium is the mean temperature of the whole day (24h) or it is the mean temperature of only the sunlight hours? and if also want to know, if we chose the mean temperature of the whole day can it still give us good approximation about temperature loss in PVSOL??
Q2: Can PVSOL premium set the tilt angle and the direction of the face of the module optimally?
Hello Hayder,
A1: I'm not sure what average temperature you mean. PV*SOL obtains the temperature and irradiance for each simulated time step (usually 1 hour) for the selected location from the climate data set.
A2: You can change the inclination (tilt), which depends on the azimuth and the position of the sun. Just press the framed button.
Marcel
