Belal Posted March 23, 2018 Report Posted March 23, 2018 Dear T-Sole My question is: in your report there is electricity saving more than solar contribution, so how i will save than i gain? can you clarify please because it seems there is something is not clear for me. as i understand if i gain for example from the sun 100,000 Kw.h /year then i will save 100,000 Kw.h /year in electricity or there is difference between solar and electricity Kw.h? Thank you to clarify that. Belal Quote
Belal Posted March 24, 2018 Author Report Posted March 24, 2018 Reference to above, my question is regarding DHW and swimming pool systems. kindly find below cut sheet image attached from one report : Solar energy contribution to DHW is 60974.75 Kw.h Energy from Auxiliary heating is 16577.4 Kw.h Electricity saving is 64010,0 Kw.h As i understand Electricity saving =Solar energy contribution - Energy from Auxiliary heating Electricity saving =60974.75-16577.4 Electricity saving=44397.35 Kw.h not 64010,0 Kw.h thank you Quote
Belal Posted March 25, 2018 Author Report Posted March 25, 2018 Dear T-sol Kindly i need your clarification regarding the meaning of electricity saving , how you calculate it?> Quote
developer_ur Posted April 9, 2018 Report Posted April 9, 2018 Hello Belal, sorry for the delayed answer. We had Easter holidays in Germany. Would you please give me further details? 1. What kind of system did you select (A1, A2, ...)? 2. What did you select as additional heating (boiler, gas, oil, ...)? The savings are not calculated one to one in relation to the solar gain. If you have a gas boiler for example, you have to take the effieciency of the boiler into account (around 80 to 90%). That means that the savings in Kilowatthours for the specific fuel is higher than the Kilowatthours of the solar energy contribution. Kind regards Quote
Belal Posted April 13, 2018 Author Report Posted April 13, 2018 Dear T-Sole. Thank you for your reply. 1- A1 or A2 in all system i find electricity saving even in swimming pools not just in DHW . 2-The additional heating heater for DHW or pool is electrical. i am talking in general ,every report i find electricity saving more that solar contribution, it almost more than the solar contribution around 20%. Based on your justification above due to the efficiency of the electrical heater ,i think electricity saving 20 % still is more than the losses and efficiency difference between solar contribution and electricity saving. thank you to provide me more clarification. Belal Quote
Belal Posted April 13, 2018 Author Report Posted April 13, 2018 Dear T sole. Further to above would you please provide me the equation of Electricity saving. how we find it. Regards. Belal Quote
developer_ur Posted April 20, 2018 Report Posted April 20, 2018 Hi Belal, I had a deeper look at our algorithms. The energy savings are calculated with the efficiency of the boiler. Please double click on the boiler (even if you don't use it in your simulation) and set the efficiencies all on 100 %. After this the savings equal exactly the solar contribution. There is a second way I describe below. It is inconsistent that the heating element doesn't have it's own efficiency. I issued a bug entry in our tracking system. --- The equation for the calculation of the energy savings is equal for all fuels: savings = solar contribution / efficiency / heating value efficiency: 1. Either the efficiency of the boiler as described above or 2. the "Annual efficiency of the reference system" as defined on the tab "Savings" at the parameter dialog of the system (double click on a free area in the picture). #2 (if enabled) has precedence over the boiler efficiency. heating value: For electricity it is 1 by definition. Kind regards Quote
