February 28, 20188 yr comment_1511 Hello! Is is possible in PV-sol to simulate Solar panels mounted directly on walls of a created object? Br, Nils Report
March 1, 20188 yr comment_1514 Hello Nils, welcome to our forum! The quick and short answer is yes, it is possible to mount and simulate solar panels on a wall. To do so, place a wall: Activate the wall: and finally, place the modules: Kind regards, Marcel Report
March 2, 20188 yr Author comment_1521 Thank you for your reply! How would you do this if you created an arbitrary object on a map section? Do I need to add a wall to my object? Br, Nils Report
March 2, 20188 yr comment_1524 Hi Nils, no, you don't have to add a wall to your object. Simply activate the part of the object on which you want to place modules. To activate the part of the object, right-click on it and select "activate". Kind regards, Marcel Report
