Hi PV*SOL team. Are there any plans to increase the 5000 panel limit?
I am now regularly looking at projects above the limit both on rooftop and groundmount. It would be great to have the full system modelled in 3D even if it takes a while to run the simulation.
It is also quite hard to work with sites covering a larger area - you can't zoom out far enough to see the whole site.
On a positive note - I'm really loving the 3D import feature. Now I have the settings right I am able to work with some large and complicated buildings.
Thanks
Hi James,
yes, we have plans to increase the 5000 limits and we are working on that for the next main version (which is due in autumn). This is a complex task however and involves a lot of refactoring and testing, so we can't come up with the quick solution unfortunately.
We're glad that you like the 3D feature!
