Fresh water demand for pools
Hi,
When modelling a pool in T*SOL, the value for "Daily freshwater demand" should include the amount of water needed to replace water lost through evaporation? or does T*SOL deal with it automatically?
Thanks!
Hello Campo Solar,
in T*SOL evaporation is only taken into account for the calculation of heat losses. If you have much loss of water due to evaporation you should increase the "Daily freshwater demand". I think an actual pool also doesn't have a control for the water level.
Kind regards
  • 2 years later...
Is it somehow a way to intervene and correct automatic data or introducting some themal loss for whatever reason?
  • 8 months later...
Do you mean Tsol calculates either evaporation losses. Besides this  also pool (small) temp decrease is calculated. depending on of (small) consequent water ingress to replace lost water (50 litres forfait).
As I understand 50 litres water ingress (and consequent) temp decrease of the pool is a forfait, irespective of evaporation rate, volume of the pool, loss for water splashing out of the pool
