Dear All
I wander how to configure the software to achieve the following:
% solar used on site without storage is c.50%
Kindly see the example below for a clear explanation:
Total AC output: 131294kWh
Direct PV to loads = 62702 kWh which corresponds to 47.8% of the Total AC output above.
What I am looking for is how to tell the software to utilize 50% of Total AC output directly to the loads leave the other 50% for the storage and grid feed-in?
Please let me know if you need a further info!
Regards
  • Aboud changed the title to How to assign % of the total AC output to be fed directly to the load?
Dear Aboud,
the fraction of the generated PV energy that can directly be used by the loads is not a design parameter but a result of the simulation. In order to get more own consumption you would have to tweak e.g. the load profile (use a profile that matches the PV generation profile a bit better). In this manner you can get closer to the result that you want to get. But you can't just input
It really depends on a lot of factors, like the simultaneousness of PV and load, the respective power values and more.
  • Thanks 1
16 minutes ago, developer_mh said:
Dear Aboud,
Many thanks martin
As far as I understand, the more the load value is closed to the PV installed capacity 'Regardless other factors like location, etc' the more PV is is directed to load?
Could you mention a trick/ parameter in the software which will change the amount of PV to load when modified?
Regards
