Aboud Posted January 9, 2023 Report Posted January 9, 2023 Dear All I wander how to configure the software to achieve the following: % solar used on site without storage is c.50% Kindly see the example below for a clear explanation: Total AC output: 131294kWh Direct PV to loads = 62702 kWh which corresponds to 47.8% of the Total AC output above. What I am looking for is how to tell the software to utilize 50% of Total AC output directly to the loads leave the other 50% for the storage and grid feed-in? Please let me know if you need a further info! Regards Quote
Aboud Posted January 17, 2023 Author Report Posted January 17, 2023 Hello, Any help would be appreciated! Thank you Quote
developer_mh Posted January 17, 2023 Report Posted January 17, 2023 Dear Aboud, the fraction of the generated PV energy that can directly be used by the loads is not a design parameter but a result of the simulation. In order to get more own consumption you would have to tweak e.g. the load profile (use a profile that matches the PV generation profile a bit better). In this manner you can get closer to the result that you want to get. But you can't just input On 1/9/2023 at 3:19 PM, Aboud said: % solar used on site without storage is c.50% It really depends on a lot of factors, like the simultaneousness of PV and load, the respective power values and more. Hope that helps, kind regards, Martin 1 Quote
Aboud Posted January 17, 2023 Author Report Posted January 17, 2023 16 minutes ago, developer_mh said: Dear Aboud, the fraction of the generated PV energy that can directly be used by the loads is not a design parameter but a result of the simulation. In order to get more own consumption you would have to tweak e.g. the load profile (use a profile that matches the PV generation profile a bit better). In this manner you can get closer to the result that you want to get. But you can't just input It really depends on a lot of factors, like the simultaneousness of PV and load, the respective power values and more. Hope that helps, kind regards, Martin Many thanks martin As far as I understand, the more the load value is closed to the PV installed capacity 'Regardless other factors like location, etc' the more PV is is directed to load? Could you mention a trick/ parameter in the software which will change the amount of PV to load when modified? Regards Quote
