Hello,
I have a problem with my system. The simulation result doesnt change if i switch between the system with battery and without battery.
The battery is not charging. I also tried larger batteries, but unfortunately nothing has changed. SOC chart is 4-6%.
I would also like to know how to assign a battery to each Deye inverter. Currently, batteries can only be assigned to one inverter.
Hello David Beránek
could you send the two project files with and without the battery as private message here in the forum so I can have a look into it?
This is a known limitation of our configuration possibilities at the moment.
