January 4, 20233 yr comment_9517 Hello, I have a problem with my system. The simulation result doesnt change if i switch between the system with battery and without battery. The battery is not charging. I also tried larger batteries, but unfortunately nothing has changed. SOC chart is 4-6%. I would also like to know how to assign a battery to each Deye inverter. Currently, batteries can only be assigned to one inverter. Report
January 9, 20233 yr comment_9547 Hello David Beránek could you send the two project files with and without the battery as private message here in the forum so I can have a look into it? On 1/4/2023 at 10:22 PM, David Beránek said: Currently, batteries can only be assigned to one inverter. This is a known limitation of our configuration possibilities at the moment. Kind regards, Frederik Report
