tommasocapietti@gmail.com Posted May 21, 2016 Report Posted May 21, 2016 Hello,  I recently purchased the PV-SOL Premium and I can't run simulations or reports because on the bottom of the page I read the error "First, please define a valid system in the 3D visualization". No matter what type of system I select I can't run any report in 3D. What do I need to do?  Thanks,  Tommaso Quote
developer_mh Posted May 23, 2016 Report Posted May 23, 2016 Hi Tommaso, Â when you first open PV*SOL premium, there is no PV system planned yet. You will have to design your system first, and then you can run simulations. If you'd like to load a predefined system first, you can go to the first page of the program where you can find some example projects to explore. Â If you don't want to design your system in 3D, you can go to page "System type, climate and grid" and uncheck the option "Use 3D Design". Â Good luck with your first PV system! Martin Quote
