November 28, 20223 yr comment_9311 Hello, Like the title say, i need help to shape the roof of a building in a certain way. As you can see in the image attached, my goal is to either remove that bit of the roof (the triangular bit) or find a way to make it 90º, but just that one side. I have tried the second option by adjusting the offset, but then after adjusting the building's dimensions it becomes like that. Any help will be much appreciated. Thank you for your attention, Zelev Report
November 30, 20223 yr comment_9326 Hello Zelev, you can achieve this configuration by editing the Attic Storeys of a building with hipped roof. You have to change the Shift of Width after unchecking Centered first: Kind regards, Frederik Report
