Maria Eduarda Posted October 18, 2022 Report Posted October 18, 2022 I'm tryin to add a new module, so i copy a existing module (VERTEX TSM -510-DE18M) and configure to the new module (VERTEX TSM -590-DEG20C.20). Infos get correct, but module design is not the same, white frames are appearing (probably cause the 510 module dimensions are 2187x1102mm and 590 module are 2172x1303mm), and i dont know how to solve this. I tried to change only electrical and dimension parameters, but had no results. Theres a specifc topic in the edit tab where i can define this design parameter? Quote
developer_fw Posted October 21, 2022 Report Posted October 21, 2022 Hello Maria Eduarda This unfortunately still seems to happen sometimes. I opened a new ticket regarding your issue and forwarded it to our 3D developer. Kind regards, Frederik Quote
