October 17, 20224 yr comment_9024 Hello everyone, I am hoping someone may be able to help with a few queries around the Financial Analysis & Economic Efficiency Tab and what each tab refers to. The basic figures I am wanting to input are: Cost to customer is £25,272.00 Cost per kWh for my customer is 0.34p Annual kWh is 15,600kWh Consumption to be used on site will be 90% (he is also having battery storage) The remaining 10% will be sold back to grid at 7.5p kWh When I am looking at the simulation results the annual yield is only at 990 kWh/kWp but the we know the yield will be circa 28,000 kWh I am just just confused as to what I should be inputting where, any help will be very much appreciated. I am trying to get my company to purchase the software and looking to show them an example using one of my directors properties. Many thanks for any help Dan Report
October 24, 20224 yr comment_9075 Hello Dan Ogden, On 10/17/2022 at 11:57 AM, Dan Ogden said: Cost to customer is £25,272.00 You did put this right, it is the investment costs of your customer. On 10/17/2022 at 11:57 AM, Dan Ogden said: Cost per kWh for my customer is 0.34p You can create your own from-grid tariff with those 0.34p per kWh: On 10/17/2022 at 11:57 AM, Dan Ogden said: Annual kWh is 15,600kWh You have to put this value as Consumption. If you have measured values, perfect. If not, you have to estimate typical distributions. On 10/17/2022 at 11:57 AM, Dan Ogden said: The remaining 10% will be sold back to grid at 7.5p kWh You have to create your own feed-in tariff with the value of 7.5p per kWh: On 10/17/2022 at 11:57 AM, Dan Ogden said: When I am looking at the simulation results the annual yield is only at 990 kWh/kWp but the we know the yield will be circa 28,000 kWh The 990 is specific, which means 990kWh per kWp. Regarding you 32.4kWp generator output this yields to ~32,000kWh. I hope this gives some hints into the right direction! If you have further questions, feel free to ask! Kind regards, Frederik Report
