How To Show Modules On Roof Of Imported Picture
Dear Eddie,
in order to be able to place pv modules on the building you would have to build it in the 3D environment of PV*SOL premium. You can import the footprint of your building into PV*SOL ('Map Section' -> 'Load from Hard Drive') and then use the Tool 'Sketch a 3D polygon' to draw the circumference around your footrpint. After that, use right-click 'Extrude 3D Object' to give it the proper height. After that, you can place modules as to your wishes.
Hope that helps,
Martin Hofmann
