How to determine the scale of an imported screenshot in 3D?
Hello Rakesh,
the scale is determined automatically from the map infos
In case you have exact information about certain lengths, for example the length of the ridge, you can adjust the scale manually after closing the window with Select:
I hope this helps.
1 hour ago, developer_fw said:
Hello Rakesh,
I hope this helps.
Hi,
I wanted import 2D photo into PV sol , how do i get theĀ  scale right ?
  • developer_mh changed the title to How to determine the scale of an imported screenshot in 3D?
