Venco Gary Posted March 17, 2022 Report Posted March 17, 2022 Operation time is in the time frame of Feed-in / Export Tariff vaildity . But no result for electricity export. PV MHS offical.pvprj Quote
Venco Gary Posted March 17, 2022 Author Report Posted March 17, 2022 And why simulation has no results per module area like that in picture? It's very important to my analysis. Quote
developer_mh Posted March 17, 2022 Report Posted March 17, 2022 Hi Venco Gary, in your feed-in tariff, you have the share of remunerated energy set to 0%. You should set it to 100% if all of the energy that is fed into the grid is remunerated. Then you'll get non-NaN values: Quote And why simulation has no results per module area like that in picture? It's very important to my analysis. Your project has a lot module areas (nice project by the way!). In order to save memory, we restrict the results per module area on projects with less than 20. You can change that setting, on your own risk. Close PV*SOL, then open the PVSOL.ini file in a text editor. You can find it here: C:\Users\USERNAME\Documents\Valentin EnergieSoftware\PVSOL premium 2022\PVSOL.ini Locate the attribute MaxNumberOfModuleAreasForResults and change the value to more than 31, as your project as 31 module areas. Save the file and start PV*SOL again. Then force a new simulation under Options -> Force simulation. Then the module area results should show up. Hope that helps, kind regards, Martin Quote
Venco Gary Posted March 18, 2022 Author Report Posted March 18, 2022 Thanks for your patient help. But after changed the data you mentioned , I can get only energy in kWh/m2. May I get result per module area what I mentioned before because it includes more details? Such as PV surface and yield for every building. Quote
Venco Gary Posted March 18, 2022 Author Report Posted March 18, 2022 And after deleting some buildings ,I can get the result what I what. Actually I have changed all MaxNumber to 40 in that text editor. Quote
