Paul Posted March 11, 2022 Report Posted March 11, 2022 Good day, I trying to figure out how I can do the string design using 12.5kW Solar edge inverter as it has only one MPPT with 2 string input. is it possible to create a DC combiner configuration on PVsol? Â Attached is the pv module data sheet that I am using. 380.9121.3 - POWERFOIL - 2900 SA - 20210225.PDF Quote
developer_mh Posted March 15, 2022 Report Posted March 15, 2022 Hi Paul, you'll have to activate the polystring option in the configuration dialog. Then you can combine the strings and modules as you wish, in series or parallel. Hope that helps, kind regards, Martin 1 Quote
