January 26, 20224 yr comment_6668 Dear all, I'm trying to learn how to design a carport but I have no clue on how to even start doing it. I searched in the forum related topics but with no sucess. Anyone has any tips? carport example: Thank you all! Report
January 26, 20224 yr comment_6669 Hi Turtles, Unless you need a good graphical presentation for a customer the easiest way would probably be to create a custom system in "module mounting". So basically a ground mount with the desired dimensions being pre calculated to a certain number of panels. Like this: Report
January 26, 20224 yr Author comment_6670 Hello Jimmy, Thank you for your answer and support. Yes, this will work just fine. In reality the support structure would be different but this is what I was looking for! Report
January 12, 20233 yr comment_9561 Hi Jimmy, Great idea to use mounted system! I just recently completed carport desing based on this post. Thanks a lot! Report
September 19, 20233 yr comment_14234 Hey @chudy14, your project looks great! I'm currently writing my Bachelor Thesis about different ways of implementing solar carports in parking infastructure. Therefore i also want to simulate different projects in PVSol. Do you maybe have some more details of your project above? How did you manage to get this alignment (V-formation)? I tried it with two seperate polygons per parking row (and creating pv rows facing each other in order to build the V-formation) but then i always have to much space left between the V-formation. I would very much appreciate your help. Thanks a lot! Report
September 21, 20233 yr comment_14258 not sure what you ment there @Pumperniggl, I made seperate rows one facing east, one facing west, and i can drag and drop them 'against' eachother. collision is on and thus no spacing in between at the design. it will ask for "connect to array" with a followup this is not possible due to different orientations. But nevertheless in general: interesting to use the module mounting to design carports. I always made a solid building and used the module coverage option. But this way is much more elegant and visually better looking. Great idea @Jimmy !! @devs, i would not mind this kind of T-shaped module mounting to be added to pvsol in addition of the tilt/EW and facade option. It is a very common design for carports. Report
September 21, 20233 yr comment_14259 Dear Peter_, thank you for your contribution. Currently, there are no plans to add a dedicated carport construction in addition to the existing formations. Nevertheless, I have forwarded your request to the appropriate developers. Kind regards Mikio Report
October 24, 20233 yr comment_14427 Thank you Turtles, that's a helpful question, I'd like to design my own construction kit for a Solar Pergola instead of a Solar Carport. I'll check if it is also possible to design more difficult geometries for complex Pergolas that attach to the house smoothly. Report
