October 4, 20215 yr comment_6068 When I start building in 3D, I load the map from google maps, then I build the building according to the parameters that are measured in google land. at the same time, the scale of the building does not coincide with the scale of the previously loaded image from google maps. before that everything worked perfectly and corresponded to the scales. what could be the reason for the scale mismatch? Report
October 5, 20215 yr comment_6070 Hi Andrii, this is interesting. Could you provide us a project file with the described map section and 3D model? You can send it here in the forum as private message. Thanks a lot, kind regards, Martin Report
