April 10, 201511 yr comment_362 Hi, I have the following problem: I don't know why I'm getting such big Regulation of radiation peaks losses (see attached file). Can someone explain what it's this factor for PVSol? maybe I understood it wrong and I'm not seeing what is really my problem. I would be very grateful for any help you are able to provide. Report
April 14, 201511 yr comment_368 Hello diegov, It is a question of dimensioning the inverter. You have a sizing factor of about 131%. This means you have a relatively small inverter compared to your module field size. In addition the irradiation at your location is very high. So, you have a lot of times with high irradiation were the incoming energy from the pv field is cut off by the inverter because the inverter is too small. You should select a bigger inverter. Best regards Your Technical Support Report
April 15, 201511 yr Author comment_369 I tough it was something like that, but I wasn't really sure. Thank you very much. Report
