Yash Posted May 18, 2021 Report Posted May 18, 2021 Hello dear developers, I want to add my climate data for which i have exactly made the .dat file according ro the given format by PV*SOL. But the moment i add the data, it says Conversion failed. Â I would sincerely look forward for some help kefergasse.dat Quote
developer_fw Posted May 18, 2021 Report Posted May 18, 2021 Hi Yash, please refer to this thread: Your file uses SPACE characters instead of TAB characters at the marked spots: I hope this helps! Best regards, Frederik 1 Quote
Yash Posted May 18, 2021 Author Report Posted May 18, 2021 Thanks a lot, this worked for me. The file is added now.  I just have a last query. Now since this newly created file is added in meteosyn, do i have to additionally now change the location or the program will assume this climate data for my simulation? Quote
developer_fw Posted May 18, 2021 Report Posted May 18, 2021 Hi Yash, no, the import only imports the climate data. You have to select the data separately. Best regards, Frederik Quote
Yash Posted May 18, 2021 Author Report Posted May 18, 2021 I am sorry but the location after importing doesn't appear in the list. Is there a different way to access it? Once again thank you for the assistance so far  Quote
developer_fw Posted May 18, 2021 Report Posted May 18, 2021 Hi Yash, that is weird, I tried your file and it doesn't show up in the Austrian list but in Slovakia! We investigate this issue in MeteoNorm/MeteoSyn. Best regards, Frederik Quote
Yash Posted May 18, 2021 Author Report Posted May 18, 2021 Yes that seems weird. I rectified my coordinates, and they are for a location in vienna. I would eagerly await for your solution over this ( if it is possible to debug). Â Thanks for your help so far. Kind regards, Yash Bhosale Quote
developer_fw Posted May 18, 2021 Report Posted May 18, 2021 Hi Yash Bhosale, Definitely, I tested the coordinates with openstreetmap before: MeteoSyn or MeteoNorm puts those off: We're on it. Best regards, Frederik Quote
developer_fw Posted May 31, 2021 Report Posted May 31, 2021 Hi Yash Bhosale, I had another look into the coordinates and while they are correct using map providers like Openstreetmap, BingMaps or GoogleMaps, PV*SOL unfortunately needs a special format as described in https://help.valentin-software.com/pvsol/2021/en/pages/system-type-climate-and-grid/meteosyn/#options I did not double check it since I assumed from your request that you did do this already. By using the converted coordinates 48.0636,-16.3600 everything works fine. Best regards, Frederik Quote
