May 18, 20215 yr comment_5461 Hello dear developers, I want to add my climate data for which i have exactly made the .dat file according ro the given format by PV*SOL. But the moment i add the data, it says Conversion failed. I would sincerely look forward for some help kefergasse.dat Report
May 18, 20215 yr comment_5462 Hi Yash, please refer to this thread: Your file uses SPACE characters instead of TAB characters at the marked spots: I hope this helps! Best regards, Frederik Report
May 18, 20215 yr Author comment_5464 Thanks a lot, this worked for me. The file is added now. I just have a last query. Now since this newly created file is added in meteosyn, do i have to additionally now change the location or the program will assume this climate data for my simulation? Report
May 18, 20215 yr comment_5466 Hi Yash, no, the import only imports the climate data. You have to select the data separately. Best regards, Frederik Report
May 18, 20215 yr Author comment_5468 I am sorry but the location after importing doesn't appear in the list. Is there a different way to access it? Once again thank you for the assistance so far Report
May 18, 20215 yr comment_5469 Hi Yash, that is weird, I tried your file and it doesn't show up in the Austrian list but in Slovakia! We investigate this issue in MeteoNorm/MeteoSyn. Best regards, Frederik Report
May 18, 20215 yr Author comment_5470 Yes that seems weird. I rectified my coordinates, and they are for a location in vienna. I would eagerly await for your solution over this ( if it is possible to debug). Thanks for your help so far. Kind regards, Yash Bhosale Report
May 18, 20215 yr comment_5471 Hi Yash Bhosale, Definitely, I tested the coordinates with openstreetmap before: MeteoSyn or MeteoNorm puts those off: We're on it. Best regards, Frederik Report
May 31, 20215 yr comment_5528 Hi Yash Bhosale, I had another look into the coordinates and while they are correct using map providers like Openstreetmap, BingMaps or GoogleMaps, PV*SOL unfortunately needs a special format as described in https://help.valentin-software.com/pvsol/2021/en/pages/system-type-climate-and-grid/meteosyn/#options I did not double check it since I assumed from your request that you did do this already. By using the converted coordinates 48.0636,-16.3600 everything works fine. Best regards, Frederik Report
