March 30, 20215 yr comment_5230 Hi, Information about The Trina Vertex TSM DE19 has been available for a while now and the module still isnt available in the database. Is it possible to get Trina to push this module asap? (Primarely 540 W's, which looks to be the most common produced). We have tried to get a export from PVsyst through import of a .pan file, but isnt all clear to get that right. If possible, the Vertex TSM-DE20 also is of interest. Best Regards Daniel MA_Datasheet_Vertex_DE19_202011.pdf MA_Datasheet_Vertex_DE20_202011.pdf Report
March 31, 20215 yr comment_5236 Hi Daniel, I forwarded your request to our database team. Meanwhile you could use https://help.valentin-software.com/pvsol/2021/en/databases/components/pv-modules/ to create your own database entry so you could already continue your planning. The only unknown in the datasheets is the IAM which you could set to a conservative 0.95. When this last parameter is known, just exchange it in your own created entry to update your simulation results. Best regards, Frederik Report
