Muhammad Idrees Posted January 11, 2021 Report Posted January 11, 2021 PV electric generation in pdf report is correct because I confirmed it by doing manual calculations. But the values in the excel file are not correct. Please guide me regarding this. Quote
developer_mh Posted January 12, 2021 Report Posted January 12, 2021 Hi Muhammad, when importing or viewing the csv data in Excel, you should make sure that the decimal separator (point or comma) in Excel is set correctly. Open the csv file that you exported from Excel with a text editor Check which decimal separator is used Open Excel (without having the csv file opened) Go to File -> Options -> Advanced and set the decimal separator as found in the csv file Then open the csv file in Excel Hope that helps, kind regards, Martin Quote
Muhammad Idrees Posted January 12, 2021 Author Report Posted January 12, 2021 I have done all of this before. I know how to convert the CSV data. But still the excel file is giving the wrong values. Can you check by yourself, I have attached the files. Quote
Muhammad Idrees Posted January 12, 2021 Author Report Posted January 12, 2021 Here, I have also attached the converted CSV file. Kindly find the attachment. Quote
developer_mh Posted January 12, 2021 Report Posted January 12, 2021 Hi again, thanks for the files. What happened here is that both your list separator and your decimal separator are commata (,). This can't work. Try to set the decimal separator to a point (this is a Windows system setting) or set the list separator for the export in PV*SOL to a semi-colon (;), like so: Hope that helps, kind regards, Martin Quote
Muhammad Idrees Posted January 12, 2021 Author Report Posted January 12, 2021 Yes, this solved my problem. Thanks for your support and really appreciable work. PVSOL generates correct files, but the problem was a mismatch between the list separator in PVSOL and in my system settings. Quote
