Name wont change on arbitrary buildings in the pv sol report
I have created four buildings and renamed them with their real property names in the 3D design.
But when i create the report or when I am outside the 3D design it still says Arbitrary building instead of the correct name that I changed it into.
See attatched pictures
Hi Patrik,
the name you have to change in 3D is the module area name, not the building name. At least once the module areas are created. Module areas are named by the name of the building at the time of their creation.
So, in order to change the module area name afterwards, just go into the configuration panel and change the names of the module areas in the lower section there:
