Im often working with flat roof systems that has the same mounting system and panels (angle, skip distance and so on)
And i can save the created mounting system and also mark it to save as default.
When i restart PV sol and start another project, the mounting systems that I saved as default is no longer there.
How do you save the mounting systems so that I dont have to start from scratch? If this is possible today, how do you make it work?
And if not possible, can this be a feature in a new release?
