Hi Everyone,
I would like to ask if it is possible to access the specific annual yield for the different Module areas separately (not only the summarized value for the whole system), in the results or the report?
I can see that there is a a section called 'Module Areas' in the report, but neither PV Generator Output, or the Spec. Annual Yield is not disclosed here, only for the whole system at the beginning of the report. Is there a way to access to any of these information for the Module area level?
Thank you in advance!
Best, Andras
Hi Andras,
in the current version, PV*SOL premium 2020 R9, there is a bug when simulation large PV systems or inverters with plenty of MPP trackers that prevents these module area specific numbers to show up in the results section. The bug will be fixed with the upcoming release.
In the meanwhile you can use this work around. Open the file
C:\Users\USERNAME\Documents\Valentin EnergieSoftware\PVSOL premium 2020\PVSOL.ini
and adjust the fields "MaxNumberOfInvertersForResults" and "MaxNumberOfMppsForResults" in this row:
<Results SaveHourlySimulationResults="False" SaveOneMinuteSimulationResults="False" SaveIVCurves="False" CalculateYieldLossDueToShading="True" MaxNumberOfInvertersForResults="10" MaxNumberOfMppsForResults="40" FeedInModel="1" WithIvCurves="0" IvCurvesMppTrackerNr="1" />
The numbers must be higher than the corresponding quantities in you project.
MaxNumberOfInvertersForResults="20" MaxNumberOfMppsForResults="100"
Hope that helps, and sorry for the inconvenience caused,
