I am having trouble including the inverter model: CPS-SCA50KTL/US-480
When I configure my solar field with this created inverter, it says it is not compatible. I tried using a similar one with different numbers that was in the database and it did it just fine. I couldn't see this inverter in the database for PV*SOL.
https://www.enfsolar.com/pv/inverter-datasheet/11072/33695?utm_source=ENF&utm_medium=inverter_list&utm_campaign=enquiry_product_directory&utm_content=13983
Hi ChaseSecrist,
I will forward this enquiry to our database team so that they can enter the inverter.
How does PV*SOL say that the inverter is not compatible? Can you give us more detail on the configuration you wanted to achieve?
Thanks in advance, kind regards,
  • 2 weeks later...
