ashraf_elawad Posted June 18, 2020 Report Posted June 18, 2020 Good afternoon, I'm using the PV*SOL 2020 version and I have inverter configuration problem . When I choose select configuration using Sungrow SG110CX inverter I get this error of " No suitable inverter configuration ... " But when I try to use the same inverter in manual configuration, this works well. So, What is the problem with the selection configuration ? knowing that I am using the same system with the same panels: suntech STP330-24/Vfw Kind regards Quote
developer_mh Posted June 19, 2020 Report Posted June 19, 2020 Dear Ashraf Elawad, thank you for reporting this problem. We are currently analyzing the issue, and we will get back to you as soon as we have an answer. Kind regards, Martin Quote
developer_mh Posted June 30, 2020 Report Posted June 30, 2020 Dear Ashraf, we were able to identify the problem. A solution will be published in the next release, PV*SOL premium 2020 R9. The solution will fix the issue that the automatic configuration is not able to find a valid configuration for the Sungrow SG110CX. Kind regards, Martin Quote
