Mr Jimmy Posted March 31, 2020 Report Posted March 31, 2020 I have downloaded and installed pvsol premium 2020. i have successfully imported a sketchup model using a DAE version. How do i re orientate the model to the correct compass setting? it is currently sitting at 180* which is close but not correct as the location is Thailand  Many thanks Jimmy  Quote
developer_mh Posted April 1, 2020 Report Posted April 1, 2020 Hi Jimmy, you can right-click on the imported model, choose "Edit" and then rotate the object. Hope that helps, kind regards, Martin Quote
DroneOperator0 Posted March 26, 2025 Report Posted March 26, 2025 (edited) Model is flipped on the side, followed same procedure like last one which was oriented correctly. Â how to rotate the model in Z axis? Â Â EDIT: Solved this Rotaing in Blender Edited March 26, 2025 by DroneOperator0 Quote
DSchwer Posted July 11, 2025 Report Posted July 11, 2025 As of today there are options in the "edit" menu which change the orientation in the z axis. I don't know how they are called in english, but it should be clear from the screenshots which selections to change. Quote
