March 23, 20206 yr comment_3617 Hello, In the options, I have marked 3 phase installation. Why does the diagram show only one phase. Thank you in advance for your answer. Report
March 24, 20206 yr comment_3621 Hi Joey, this is label appears when you have a single-phase inverter on a 3-phase grid. If you have two single-phase inverters, two labels appear: If you have three single-phase inverters (or any number of 3-phase inverters), nothing appears, as the phases can be distributed evenly. If you have a number of inverters that is not divisible by 3, the phase configuration appears: Hope that helps, kind regards, Martin Report
