Image an Installation of 1000+ PV Modules, we will have to do 1000 times the configuration process to calculate to outcome...
How can we do this all in once ?
Also the configuration is giving an red X. The max income is not set right in PVSOL, see image
Hi Remu,
you can use the Enphase inverters in the automatic or manual configuration like any other inverter as well. Here in my example I have 44 modules on the roof, so I use 44 Enphase inverters:
You can also select all Enphase inverters using the link under "Suggest Configuration", and let PV*SOL search for a valid configuration by clicking on the arrow.
Regarding the DC and AC power values of the Enphase IQ7-60. Its values are correct in the database:
You will have to allow for sizing factors (DC power / AC power) of above 140%. You can do so by clicking on "Configuration Limits" and then set the upper limit to 150 for example:
  • Like 1
