HPJ Posted February 5, 2020 Report Posted February 5, 2020 Hi, I'm trying to calculate using a tariff system where there's no compensation for the energy that is supplied to the grid and there's a fixed price for what is imported from the grid. That is a system where what is supplied to the net is worthless and there's no balance to keep track of. If it's supplied to the net, it's , in essence, lost. How would I go about setting that up? Â Thanks. Â /HP Quote
Vishnu Posted February 7, 2020 Report Posted February 7, 2020 Hey there, I can think of one way which might help you here. As there is nothing you can earn from feeding into the grid, you can simply set the feed-in regulation to 100% at the feed-in point. This setting allows the system to act as zero grid injection system. (All that excess energy after self-consumption is down regulated at the feed in point) Did i answer your question? Â Quote
ChaseSecrist Posted July 17, 2020 Report Posted July 17, 2020 I have playing around this idea and from my understanding, HPJ is wanting the solar array to feed straight into the customers power and the grid compensate the remaining power the solar array is not producing. I am needing the same situation and the above solution does somewhat of that but if you place it at 0%, it is not feeding into the system, but it's also not feeding into the consumption as the below photo shows.  The way I see it is where the production of energy for the solar field should go directly to the consumption and supplemented by the grid for the remaining. Quote
ChaseSecrist Posted July 17, 2020 Report Posted July 17, 2020 Can PV*SOL adjust the amount of energy production from the solar array going into the consumption or have some sort of net metering adjustment? Quote
