Hi Robin,
you are not doing something wrong, and it is not a bug, it is just a missing feature. But I am glad to be able to announce this feature for the next major release PV*SOL premium 2020 R1. We will publish it in January 2020 if all goes according to plan.
Hi Robin,
no, I am afraid that is not possible. You can have more than 1 inverter configuration for two combined module areas, but they have to be identical. In this case you can enter a number greater than 1 in the first field here:
But I guess that this will not solve your problem. Right now, there is no other possibility, sorry.
  • 2 months later...
Hi Robin,
we are currently in the stage of testing. If our tests go well, the release will be forwarded to the "publishing" stage, where other people also perform some tests. After that it will be released. This process usually takes less than a week, but always depends on how the tests go and what else our team and the publishing team have on their todo lists.
