November 29, 20196 yr comment_3178 How do I configure two module arrays to 4 inverters? I don't seem to get the options to add an inverter or to dupiclate the existing one. Is this a bug or am I doing something wrong? Report
December 2, 20196 yr comment_3181 Hi Robin, you are not doing something wrong, and it is not a bug, it is just a missing feature. But I am glad to be able to announce this feature for the next major release PV*SOL premium 2020 R1. We will publish it in January 2020 if all goes according to plan. Kind regards, Martin Report
December 2, 20196 yr Author comment_3182 Hi Martin, Thanks for the rapid response. Is there a way to work around it for now / to draw the strings manually onto the solars panels or something like that? Kind regards, Robin Report
December 2, 20196 yr comment_3187 Hi Robin, no, I am afraid that is not possible. You can have more than 1 inverter configuration for two combined module areas, but they have to be identical. In this case you can enter a number greater than 1 in the first field here: But I guess that this will not solve your problem. Right now, there is no other possibility, sorry. Kind regards, Martin Report
December 2, 20196 yr Author comment_3188 Hi Martin, Ok no problem. Thanks for the explanation. Kind regards, Robin Report
February 13, 20206 yr Author comment_3453 Hi Martin, I'm currently working on PV*SOL premium 2020 (R3) and it looks like this feature is not yet included, will it come in one of the next updates? Kind regards, Robin Report
February 13, 20206 yr comment_3457 Hi Robin, yes, it will arrive in one of the next updates, most probably R4. It depends on how the tests go Kind regards, Martin Report
February 13, 20206 yr Author comment_3458 Hi Martin, Nice, thx for the response! Kind regards, Robin Report
February 17, 20206 yr Author comment_3468 Hi Martin, Any idea when this new version will be ready? Kind regards, Robin Report
February 17, 20206 yr comment_3470 Hi Robin, we are currently in the stage of testing. If our tests go well, the release will be forwarded to the "publishing" stage, where other people also perform some tests. After that it will be released. This process usually takes less than a week, but always depends on how the tests go and what else our team and the publishing team have on their todo lists. Kind regards, Martin Report
