September 30, 20197 yr comment_3020 When i start a new project i cannot pass the 3D design phase, as soon as i open the window it pops up a error saying "Fehler beim Zeichnen des Prims" and after pressing ok it closes. How can i fix this error? Report
October 7, 20197 yr comment_3029 Hi Alexclavijon, in order to debug this, it would be helpful if you could provide some more information. Which version of PV*SOL are you using? Can you send the log file "PVSOLpremium.log" ? It is located under C:\ProgramData\Valentin EnergieSoftware\log Thanks and kind regards, Martin Report
