Rexplorer 3D model – hatched areas on the roof that can't be covered
Hi everyone,
Has anyone else run into this with a 3D model imported from Rexplorer? Parts of the roof plane show up as white hatched areas and I can't place any modules on them — they don't respond to a right-click either.
What is the proper way to solve this?
Hello,
Thank you for sharing the project file.
If hatched areas appear incorrectly on an automatically generated layout area, your only option is to draw the layout area manually. Unfortunately, it is not possible to manually draw a single layout area while retaining the other automatically generated ones; instead, all automatically generated layout areas are deleted, requiring you to draw all areas manually.
We will inform Rexplorer about this issue and request a revision.
