Inverter Data
Good Day, Can you please make sure the data in PVSol Database is correct for the specified 16kW Single Phase Inverter. Something does not look correct if I compare the DC data with the Datasheet of the inverter.
Max DC Input Power should be 25.6kW
Max Input Current should be 96A
Max Short Circuit Current should be 180A
