Mark Posted Friday at 02:56 PM Report Posted Friday at 02:56 PM Good Day, can someone please assist. I need to create a project with a Hybrid Inverter and a separate battery connected to the Inverter. NOT a Battery System with a battery inverter. The battery selections are in the database that I must use but nowhere is there a selection of the free standing battery. Which system type must be used? Is it the one I highlighted below? In the database the batteries are there, but where do you add them? Quote
hotline_oh Posted Monday at 12:09 PM Report Posted Monday at 12:09 PM Dear Mark, Thank you for your inquiry. In PV*SOL, we distinguish between DC-coupled and AC-coupled battery systems. We assume you intend to use a hybrid inverter with an AC-coupled battery system. You must select the hybrid inverter twice in the program: once when configuring the modules (as the PV inverter) and again when selecting the battery system. When selecting the battery system, please ensure you choose a battery system with AC coupling. Quote
Mark Posted Monday at 01:22 PM Author Report Posted Monday at 01:22 PM Thanks. I figured it out. It should be a DC Intermediate Coupled battery inverter as per below. I had to create my own setup in the database. I just have another few questions, see below in the SLD, I have questions in red: Quote
hotline_oh Posted 21 hours ago Report Posted 21 hours ago Dear Mark, Thank you for your inquiry. Unfortunately, the editing options for the single-line diagram are limited. You can only make the desired changes manually using other software. You have the option to export the single-line diagram as a PDF, PNG, or SVG file. We have forwarded your requests to our development team. Quote
