J. Esteban Posted November 7, 2025 Report Posted November 7, 2025 Good morning everyone, Is it possible to update the reference satellite image used for the 3D layout after I’ve already created a 3D design? If so, where can I find this option? Or would I need to start the design from scratch and select the satellite image again? Kind regards. Quote
hotline_oh Posted November 10, 2025 Report Posted November 10, 2025 Dear J. Esteban, Thank you for your inquiry. Unfortunately, it's not possible to replace or subsequently change the map area. You would have to start the project again. You could try placing an open area at the edge of the map and replacing the texture of that open area with the missing map section. However, precisely scaling and adjusting the missing area would likely be quite difficult. Quote
