CarlSEL
Everything posted by CarlSEL
  1. Hi, Can you please explain to me where the IAM is calculated within the losses with regards to PV modules? Also, what values are used in these calcs? I would expect to see different values over different angles? The panel I am interested in is the Trina-510-NEG18R.28 VERTEX S+ 2024 Thanks
  2. Hi, I have noticed that when a certain amount of inverters are used the Performance ratio per inverter graph only gives one value. Is there a way of getting each individual PR ration per inverter for a site using 12no 40kW inverters? Thanks Carl
  3. I was asking about the AC cables. I have 25 330k inverters all with different lengths ranging from 100 metres to 300 metres. There is no way to manually input each cable length.
  4. Has this feature been added yet? A separate loss for each cable length would be so beneficial.
  5. Thank, I have just sent an email.
  6. Hi, Can you please tell me what would create the Grid Export in First Year to be so low. Thanks Carl
  7. Thank You!
  8. Yes but how will i get accurate production figures with the HHD utilised when it is spread across the 3no elevations? How would I work out the self sufficiency and own consumption? Thanks Carl
  9. Thank you, how do I perform the shadow simulation for each subsystem individually?
  10. Hi, I was just wondering if anybody else is seeing some unrealistic production figures since Meteonorm 8.2 was available? The figures seem to be unachievable on most projects even with extra losses included. I have carried out sunlight hours checks over the past 80 years and maybe its just because we have had a poor couple of years. TIA Carl
  11. Hi, the attached design keeps crashing on the final saving after the shading analysis. Can you tell us why this is happening, thanks. Carl Distribution Depot EW CP.pvprj
  12. Hi, I am designing a large university campus that has one main MPAN Meter with one Half Hour Data values. Due to the size of the site I have had to split the designs across two saved files. Can you tell me how I can create a single production, PR, export, own consumption and self sufficiency for the site overall? I can download the simulation values on excel but was wondering what values I would need to calculate to create the above overall values. Mainly own consumption and self sufficiency. Thanks
  13. Hi, Yes I think maybe 'Under 'PV System Energy Balance Balance' > 'Configuration', we also specify the module-specific partial shading for each inverter and MPP tracker. Does this information help you?' is what I am looking for. Thanks
  14. Thank you for you response. Yes what is the difference in accuracy when using the minute values against the hourly? Thanks
  15. Hi, Can you tell me if there is a way I can export the shading loss % per array as an annual figure? Thanks
  16. Hi, I am wondering what is the accuracy of the exported production in hourly format when using Meteonorm 8.2? It would be helpful if you have any figures. Thanks
  17. CarlSEL
    Large Designs
    Hi, this will work if you have identical rows all alligned. If you have 200 rows all different lengths then the shading will not be straight forward I imagine.
  18. Hi, yes that work fine if you only have the one inverter but what if I have 4no 100kW inverters. How do i distinguish between Inverter 1,2,3,4 etc?
  19. CarlSEL
    Large Designs
    Hi, I am looking to create larger 3D designs on PVSol up to 20,000 panels etc I understand how to increase the panel size allowance but a lot of the time it crashes. What sort of size computer ram would I require to stop any crashes? Thanks
  20. Yes, how have you managed that?
  21. Hi, Yes I understand that I now have to select 3no SE100K-EU-(400V) Units to make 1no 100k Unit but the PVSol SLD then gives each unit an independent isolator etc. rather than just one isolator for the master. Do you understand what I mean? thanks
  22. Hi, Why does the SLD split the Solar Edge SES units up into individual inverters and not just show the Master unit? For example a 100kW Solar Edge inverter is 1no Master Unit and 3no SES units. PVSol shows this as 3no separate inverters and this is confusing the already hard to deal with DNOs. Thanks C
  23. Hi, My stakeholders have asked me to put a report together as to why PVSol is better to use for PPAs than PVSyst. I have always championed PVSol and have been given the opportunity to put this forward to hopefully change our process. Any input you could give me will be much appreciated. Thanks
  24. Hi Helen, yes I did. The way around it is to export the weather data from PVSyst and then upload to SE Designer. You are basically then using Meteonorm 8.1 and not 7.1 PVSol is still number one for me.
