Rahil Pednekar Posted August 15, 2025 Report Posted August 15, 2025 How do you currently simulate PV systems which have both battery and heating rod combined? Â Â Quote
hotline_oh Posted August 27, 2025 Report Posted August 27, 2025 Dear Rahil Pednekar, Thank you for your inquiry. We recommend the following: First, you select the thermal system. Then you select the heating element for heating domestic hot water. You can view the solar-generated heat supply in the results. In the diagram editor, you can read out the data series for the heating rod and import it into Excel. Â You can now import the *.csv file into the consumption dialogue and simulate your project in combination with a battery. Quote
