Hi,
I have a load curve every 15 min. One column is in the format 01/07/2024 00:00 and the sdecond colum I have my consumption values in kWh in the format 0,0.
I can't manage to load my file, I always have the same error : No read permission of the file
Thanks for the help,
Hi Sebastien,
the error message indicates that PV*SOL is not allowed to read the file. You could check the file in your file explorer by right clicking, then properties, then check the attributes at the bottom, perhaps the file is read-only. This might occur when you open files directly from Outlook for instance.
