Karina Suharevska Posted July 31, 2025 Report Posted July 31, 2025 I've been trying to add my own load profiles (consumption data) into PV*SOL, but I keep getting this error box saying: "Conversion error in the data line: 1." What could this mean? The file I've been trying to add is a CSV-file and the only data in the file is the consumption, in kWh. Time interval is 60 min, leading to 365 days and 8760 values. The CSV-file contains 8760 values in one column. Thankful for any help! ST paterina dati Ragana DUS 07.24-06.25_PVSol.csv Quote
developer_mh Posted August 1, 2025 Report Posted August 1, 2025 Hi Karina Suharevska, I guess the problem is that the time is in an unexpected format. Hours, minutes and seconds should be separated by a colon ":", i.e 01:00:00 instead of 01.00.00. Also make sure that no such things as in line 11 happen. Hope that helps, kind regards, Martin Quote
Karina Suharevska Posted August 4, 2025 Author Report Posted August 4, 2025 Hello! I changed table and left only kW column. It worked! Quote
