Jamie Posted July 14, 2025 Report Posted July 14, 2025 Hi, My automatic selection of inverters times out and gives me zero selection. Specifically, i want a Growatt. I select only 'Growatt' from the inverter brand selection and select all inverters with in this group. Using the select button at the bottom and then doing automatic selection, i can see the search going through fronius and Solax. It times out at 60 secs and i have no selection. This has happened 10x times in a row. Thanks Quote
hotline_oh Posted July 15, 2025 Report Posted July 15, 2025 Hi Jamie, Thank you for your inquiry. Did you press the "Deselect all" button before selecting the desired Growatt inverters? If this doesn't help, please send your project file (*.pvprj) to hotline@valentin-software.com so that we can take a closer look at it. Quote
