I'd like to know if there's an option to add different structures, such as single-post or double-post. For construction purposes, it would be helpful to add this bill of materials to the project.
If not, would it be possible to add 3D models to assemble them?
Dear Emilio,
Unfortunately, PV*SOL doesn't have a database for mounting systems, and you can't generate detailed parts lists. You can only choose from the three standard designs. For rooftop systems, you can use the import/export interface to K2 and Renusol. In this case, the detailed parts lists from K2 and Renusol are also imported into PV*SOL. For ground-mounted systems, it is theoretically possible to import your own 3D models for the mounting systems. However, we advise against this, as it is very time-consuming and usually doesn't achieve the desired results.
